Question on engine oil...overfill
#41
As previously stated, I settled on 8 quarts when I did my first oil & filter change on my wife's 2006 XK8 not quite a month ago. The oil level shows up right at the top of the "full" mark on the dipstick, right where I want it. I'll stick with 8 quarts going forward, although I'll bet that 7 quarts would do just fine in these cars as well....
#42
#43
#44
Hello - I know this thread is a couple years old, but having read this thread 3-4 times and the referenced the TSB re: dipstick replacement, I still can't seem to decipher whether I should fill the oil in my newly acquired '06 XK8 to the "max" level, or 1 quart beyond that.
I have an '06 XK8 and the dipstick part # is XR83-6752-AC.
Here is what is confusing me: The TSB references an "in model year change" for MY 2000. Would they not have corrected this situation by the time the 2006 models were produced? Shouldn't the fill level on the dipstick that comes in a 2006 model be correct to the Jaguar intended specification fill by the time the '06 models were manufactured?
Thanks for any assistance.
#45
This takes all the second guessing out of it. You didn't overfil it, you didn't underfil it.
Two reasons I think this is the best course:
1. It is always better to underfil than overfil (and by overfil I mean up to the crank). Underfil and your oil doesn't last as quite as long and gets hotter when stressed, overfil and you can do damage.
2. IF your dipstick is mismarked and IF you can actually add another quart what exactly is the benifit? It means more volume which means it won't get saturated with impurities and particulates quite as fast but if you change oil regularly that won't be a problem anyway. You will still have plenty of oil in your pan, and plenty of head pressure on the pickup.
#46
XK8 oil level high after change
Every time I take my 2003 XK8 coupe to a garage for an engine oil and filter change, after the new oil is in the level is about 3/8 inch above the max line when they put in 7.5 US quarts. I checked it after I let the car cool and sit overnight. I check it in my garage where the floor should be level. The manual specifies 8 quarts. This happened with four different garages. The dealer says the length of the dip stick is correct. Model XR83-6752-AD http://www.jagrepair.com/images/TSB/...il%20level.pdf
Could it be that all the oil does not drain out? How do you check if all is drained?
How can you get all the oil to drain?
Has anyone else had this problem?
#48
OMG ROTFL. This is the craziest thread I've read in a while. All for a little oil stick. Three pages and no definitive resolution. And then throw in those cars with replaced engines in the early Nikasil days. I wonder how many mechanics bother to look at the engine number to verify. That TSB looked clear at first. But, each time I read it I get more confused. I think I'll go add more oil tonight! LOL.
#49
rflexible,
With my wife's 2006 XK8, I've found that if I want to drain every drop of oil out of the oil pan I must lower the front end to the ground after my initial drain and then jack up the rear end a foot or so and let the car sit for five or ten minutes until the pan is finally empty. I got tired of doing that extra step after the first couple of oil & filter changes I did and decided to just leave the small amount of residual oil in the pan and start by adding 7 fresh quarts. Then I check the oil level again the next day and add oil accordingly. I usually wind up adding just under an additional half a quart. Sometimes it needs less than that. The inconsistencies used to bother me but they don't anymore....
#50
That was printed on dipsticks for a few decades.
Your running engine needs the oil at a certain level. Letting it sit all night and getting oil from the top and sides to drain back into the pan is NOT the natural state of a running engine. Stopping the engine and waiting a minute is closer to the REAL oil level that the engine requires.
IT SHOULD be a little overfull if you are checking it 8 hours LATER!!!!!!!!!!!!!
Try the "STOP ENGINE, WAIT 1 MIN" method and see if it is correct at that time.
bob gauff
jamdmyers (01-21-2016)
#51
see post #13 and thank plums
#52
#53
Actually, the way Jaguar always recommended checking the engine oil level was "STOP ENGINE, WAIT 1 MIN".
bob gauff
bob gauff
Bob has it
After a new oil/filter change to the Jag sump capacity recommendations on my 2001 XKR the oil level is about 8mm above the max mark when cold (overnight) but bang on the max hole after a run and waiting 1 minute.
Steve
motorcarman (05-31-2016)
#54
Originally Posted by cyber3d
OMG ROTFL. This is the craziest thread I've read in a while. All for a little oil stick. Three pages and no definitive resolution. And then throw in those cars with replaced engines in the early Nikasil days. I wonder how many mechanics bother to look at the engine number to verify. That TSB looked clear at first. But, each time I read it I get more confused. I think I'll go add more oil tonight! LOL."
Well, cyber3d, if you think it is ok to overfill the oil level, than don't worry about it, but for those who don't want to overfill and risk damage then don't call them crazy if they want to take a easy and reasonable precaution.
#55
#57
Maybe this results in looking over full after sitting all night, but I will change the oil same way I have for decades and let you all know if the level raised the next day after sitting.
And about the oil filter, you only pre fill oil filters that are large capacity and orientated straight up and down, such as in diesel truck engines, the big ones, because you will cause damage as pump can't fill the filter fast enough while engine running. On these little filters mounted sideways it is a non issue.
#58
#59
#60
Oil Level ?
