Quick fix antenna
Old 04-18-2015, 11:20 AM
Fulton's Avatar
post deleted Mods please remove thread.
blindside (04-18-2015)
Old 04-18-2015, 01:29 PM
Jon89's Avatar
Received 4,366 Likes on 2,855 Posts
Can you comment on the radio station reception range? My wife can still pick up a couple of her preferred local FM stations nearly 100 miles away from home using her admittedly ugly factory antenna. I doubt if an aftermarket antenna module sitting inside the trunk could do that. Let us know, please....
Old 04-18-2015, 11:04 PM
Jandreu's Avatar
I bought that same unit and it's crap IMHO. Hardly picks up anything.
Old 04-19-2015, 08:01 AM
Dennis07's Avatar
Jon,
Only testing will tell if a particular replacement antenna will be adequate for the stations you want.
But in general it's as you said ... a module in the trunk will not pull in everything that the standard, ugly pole is able to receive. "There's no substitute for aperture" ... the size of the target that an antenna presents to incoming signals.
Good luck
Old 04-19-2015, 08:44 AM
Jon89's Avatar
Dennis,
Thanks for the confirmation. Although the mast antenna is indeed an albatross, I'm not willing to risk trying this module. My wife would much rather be able to get her chosen FM stations and put up with the 1970s antenna technology in the process....
99xk8guy
05-28-2024 09:36 PM
Shawn Svacha
02-06-2022 04:53 PM
mbergen
10-23-2019 10:26 PM
Dz1rfj
07-17-2018 10:29 AM
Rablaw1971
09-11-2015 10:24 PM
Quick Reply: Quick fix antenna
