Quick Headrest Repair Questions...
I think I messed up. After I cut 12mm of the cable sheathing, there's a total of 21mm of drive cable visible (from the top of the sheathing where it was cut to the bottom of the drive cable. Does that sound right? If I put the remaining sheathing on with the metal grommet, there's still lots of drive cable exposed. What gives? Also, before putting everything back together, I tested the headrest motor with the seat switch, with the backrest back in position. It only stays on for a few seconds, then stops (both ways). Is that normal?
