Quick Injector Question....
1997 XK8 with fuel rail built into the intake.
I have the fuel pressure released, removed the plug, removed the 2 bolts and the clamp.
But the injector does not want to come out with any reasonable pressure. There isn't much to grab onto and I am afraid I'm going to break the plastic top off it trying to get it out.
So how hard should these be to pull out?
Dave
Dave
I used to have an intermittent gas smell from the engine compartment and could never figure it out and it didn't do it very often.
I think I found the source when I changed the number 8 injector. ALL and I mean ALL of the injector clamp screws were loose on every injector. Some were even loose by several turns. Obviously not a good thing as an injector could probably back out just enough to leak a little every now and then. I haven't caught another whiff of gas smell since. So if you have a phantom gas smell on a pre '99 XK8 that has the fuel rail inside the intake manifold that could be your problem.
Dave
Dave
Dave
Dave
FS[SouthWest]: 2001 S-Type & 1997 XK8 Parts
andisval
10-29-2015 12:21 PM
injainja
10-10-2015 07:09 AM
WTB[Western US]: XK8 Seat Backrest AGD- 1997-2001
XJsc-guy
10-07-2015 10:41 AM
