Quick question about door window mechanism..
In several videos (e.g. youtube) I've seen someone raise the window all the way with the door open, then close the door. The window appears flush with the rear window. On my car if I did that, the window would jut out at the top (perhaps even damaged) because it wasn't dipped when closing the door. Is my car at fault for not somehow automatically dropping the window a bit before the door closes? Thanks.
MediaBobNY (08-08-2018)
Try setting the window controllers by continuing to press the button after window is at full top or bottom until you hear a distinct click. Do it for up and down. If all else is good the windows should start dropping slightly when the door is opened.
MediaBobNY (08-11-2018)
