Quick question - which are the best spark plugs for an XKR?
Sorry, I know this subject keeps cropping up, but I checked the FAQ and did a search and couldn't find what I was looking for.
I seem to remember NGK being voted best plug, but there are several references for my car on their website.
TIA
TIA
Jaguar uses stock the IFR5N10, and according to jaguar should last 100Kmiles iirc (are yours already bad?). I always use the slightly cheaper Iridium IX version, BKR5EIX-11 (but then some heat ranges colder),:
New 4 NGK Iridium IX Spark Plugs BKR5EIX-11 / 5464 | eBay
KenneBell has changed its recommendation from iridium’s to old style copper ones, they say that under high boost the copper ones hold up better:
http://www.kennebell.net/techinfo/general-info/SPARKPLUGS.pdf
Most of us do not run these high boost ranges, and I have no experienced issues (but I also haven't run these high pressures, nor have the capability to do back to back testing).
Am now experimenting with higher boost pressures (so above 20 psi), and have gone for race plugs for just to be sure, am using the Denso IK01-24 (these are still iridium’s).
Received 2,263 Likes
Standard plugs are good for 15-20K miles, iridiums are good for 100K+ miles. Several months ago I posted some pics of plugs that had gone over 300K miles and still looked like new.
Well worth the extra money IMHO.
The NGK UK site is unequivocal in recommending NGK IFR5N10 Iridium for both XK8 and XKR 4.2
NGK Partfinder for Cars & Light Commercial Vehicles
Whilst the change interval was different for the NA and SC 4.0 models, the 4.2 Jaguar Service Schedule lists 100k for both engines.
In mid-2017, this may be a little "dated" for discussion, but those of a certain age will recall that Denso/NGK "rescued" Jag electronics and by the looks of things, they are still doing a pretty good job. Just now, for the 5.0L 2010 XKR SC engine, PartsGeek shows NGK-94940 as recommended plug. Iridium wire and a bit "pricey" at $11.50 ea. $100 for 100k miles??? Not a bad trade-off, seems to me. As for BG engine FI/Induction cleaning, I ENDORSE it !!! Especially if you (or previous owner(s)) are/were "Geezers." Again, maybe $100-200 to know (and in my case, "experience") your engine "coughing up" part of a lung on test drive is worth it!!! (This applies to '03 XJR with almost 100k miles, 6% pulley and Mina exhaust.) The "Beast of the East" is STUPID fast, shutting down a "Rice Rocket" on I-20 at 130 mph. (The guy kept looking over at me from his crouch, with a "Who the Hell is THAT GEEZER???" look. He backed off at 130 and "sat up." Road victory to immateur Geezer! Comfy, sneaky fast, low-slung, Int'l award-winning design...it puts a smile on my face every time I light it up! EHT/SC
Charlene n John
09-28-2015 06:01 AM
Beardy
09-18-2015 10:00 AM
