quick question on valve cover sealing
Old 06-16-2014 | 06:56 PM
jamdmyers's Avatar
Default quick question on valve cover sealing
I've read many threads on the secondary tensioners. I'll be doing this later in the week. Some mention the need for gasket sealer. I've purchased oem from SNG Barrett gaskets, I've never liked using sealer since the gasket is supposed to seal and if you take things apart in the future you have extra 'gunk'. Some used it with after market gaskets that probably weren't proper thickness, others mentioned a dab here or there. Where exactly would this be required. Obviously a good clean mating surface is required first....
Old 06-16-2014 | 09:24 PM
Paul Pavlik's Avatar
I used the Lincoln LS Gaskets (same as Jaguar OEM) with No Sealer, with No Leaks. Sealer should NOT be Necessary.
Old 06-17-2014 | 03:28 AM
test point's Avatar
A dab of RTV is recommended at the points that the front cover mates with the heads. Otherwise, nothing is needed. The gasket is more like a big 'O' ring than a gasket. There are brass 'stand-offs' in the bolt holes that are intended to prevent deforming the gasket caused by over tightening. Said over-tightening will crush the stand-offs, deform the gasket, crack the plastic covers and leave oil leaks that can only be repaired by replacing the covers.
I have had my covers off twice without replacing the gaskets and have no leaks but others have not been so lucky.
Old 06-17-2014 | 04:32 AM
jamdmyers's Avatar
Verified via JTIS, but wanted real world experience. Thanks
Attached Thumbnails quick question on valve cover sealing-valvecoversealant.png
Old 06-17-2014 | 07:59 AM
Fulton's Avatar
You got it, a little dab will do ya. Mine had the dab of RTV from the factory so I did the same. No leaks with OEM gasket. Trust your torque wrench, as my Japanese friend says "mouse tight, not elephant tight"
Old 06-17-2014 | 09:00 AM
dublinmike's Avatar
Thanks folks,
If I suspect a plug o ring is leaking could I sort this with rtv?
Also anyone know offhand what the torque values should be for the cover?
Thanks,
Mike
Old 06-17-2014 | 09:12 AM
Fulton's Avatar
Camshaft cover 9-11 Nm JTIS has a torque spec search
I would replace the o-rings along with the gasket.
Old 06-17-2014 | 12:50 PM
test point's Avatar
The plug rings normally come in the valve cover gasket set.
Forcedair1
05-14-2023 03:28 PM
Kevin Burnaby
06-28-2020 08:04 AM
PMKimpton
08-03-2019 08:22 PM
sogood
09-15-2015 07:35 AM
d a
09-03-2015 02:34 AM
Quick Reply: quick question on valve cover sealing
