A quickie about cam covers
I got to the stage in the last hour of daylight today, where my cam covers should have come off, except they didn't.
So the question is, do the cam covers often "stick"?
I was pulling on them, trying to be careful, but using more force than i thought i should need, and although i could get a little play, it was millimetres.
I tried prising up the cam cover on the right side with a flat blade screwdriver, thinking the cover was stuck to the gasket, but i broke a tiny chunk out of the plastic cam cover (very tiny), which served as a warning not to continue.
Intake manifold, throttle body, air filter box, header tank, coil overs and even the spark plugs have been removed.
The electrical connectors to the variable camshaft timing oil control solenoids have been disconnected, and i understand that the covers pull over the actual solenoid housing, so i don't need to take that off.
Is that right?
Wiring loom plugs that attach to the cam cover have also been disconnected from the covers.
Is that right?
Is that right?
Is that right?
Any chance you missed removing the two bolts in the center of the cam cover (between the spark plug openings)?
Roadhogg (07-11-2012)
Oh damm, you were absolutely right WhiteXKR.
When i took the coil overs out i left the connectors roughly in place, and they were covering those 2 bolts. I didn't even see them.
My payback i guess, for trying to rush the last bit in order to get a look at the tensioners. . . which look like second generaton with the wide and hollow triangular elbows on either side at the top.
I'll have another look in daylight.
Thank you WhiteXKR, and GGG.
God i amaze myself at times
Dickie_L_J_O
09-13-2015 07:44 AM
jagent
09-12-2015 09:10 AM
