Radiator cooling fans won't kick in after condenser change
Hey everyone!
After I installed an aftermarket ac condenser my radiator fans would never kick in, therefore the car is overheating in traffic. I am using old scanner to read coolant temperature, and while going around 80 km/h engine temp is like 88-92c, but in traffic today it hitted 110, and then 115 when I shut the engine off. Can changed aftermarket ac condenser mess with the car brains, or it's just that probably the fans are not connected?
V, you're new here welcome.
Please always remember to state year and model. I put it in my signature so it always auto populates.
Know this: when AC is on fan always is on automatically - always
90c is 194f. Not very hot.
110c is 230f. I've seen this on hot days stop and go traffic.
115c is almost 240f - too high imo
Frankly I don't understand how you're keeping the temp this low without any fans!
Temp sensor seems to be working. If I knew the year I'd look up fuse for you.
Checking: still no fan after key out car parked?
Did you remove fans for the job? Fans are plugged in now, right?
John
John
John
John
its 1999 XKR. Yep, still no fans after the key is out. I guess I’m keeping the temp that low without any fans just by going more than 80km/h 😀
My suspicion is that the mechanic didn’t plug the fans in, but I’m not sure. I’ll check today
Oh that would make sense, didn't realize you didn't do the job.
File this away for yourself:
Its really easy to take fans out to improve access. Just remember the nut side of the hold down screw is floating. IOW it'll drop into void if not careful.
The plugs will be really EZ to see. Let us know.
John
John
EscapedApe
12-04-2015 11:51 AM
