Radiator Replacement
Old 10-15-2016, 01:35 PM
PaulsXK8's Avatar
Default Radiator Replacement
Hi all. I have a 2003 XKR that needs a new radiator. I ordered the part but I was wondering if anyone who has already do one has any tips. It looks like you remove the plastic cover. Does that AC condenser or the oil cooler need to be replaced at the same time? Thanks
Old 10-15-2016, 02:39 PM
dsd's Avatar
dsd
dsd is offline
Can't directly help but the below thread has the instructions (in case you've not seen it):
https://www.jaguarforums.com/forum/x...adiator-60937/
Edit: this is for an 01 N/A
PaulsXK8 (10-15-2016)
Old 10-16-2016, 01:48 PM
Pristine97XK8Convertible's Avatar
The transmission fluid cooler is an integral part of the radiator assembly on my '97 XK8, so essentially you are replacing both your radiator and transmission fluid cooler in one go. Because of tight installation proximity, the A/C refrigerant pipes on mine had to be loosened in order to make room to remove the leaking radiator, thus calling for a vacuum expunge and refrigerant refill after installing the new radiator.
Are you equipped to do this job in your home garage?
monster48
09-13-2016 08:27 PM
Atlastajag1
09-08-2016 09:23 AM
MJTgroup
09-07-2016 07:00 PM
MJTgroup
09-05-2016 01:09 PM
dsd
08-27-2016 09:09 PM
Quick Reply: Radiator Replacement
