Radiator stuck in car
I was determined not to drain the refrigerant when removing the radiator from my 2002 XKR but in the long run I had to disconnect the lines to get it out. I even got the condenser separated at the bottom but no luck. Eventually it came out as an assembly. It is really tight on the right side.
PaulsXK8 (10-28-2016)
