Radio is being difficult...
1999 XK8 convertible, 135k miles and running as strong as ever.
My radio is being difficult and I'm hoping to find the answer.
I'll be listening to the radio and after about 10 minutes the station will go silent...until I press the station button again, then the sound will come back. A few minutes later is will happen again and this continues for about 20 minutes, then it wont happen until the next time I turn the radio on. Happens on all stations.
* New battery, all connections tight
* CD works fine
* No power drop from the alternator
*Antenna is fine
What the heck!?! Any ideas?
* CD works fine
*Antenna is fine
there is a "feature" built into the earlier car's radio ( I have a 98). It scan's for better higher signal versions of any channel you are listening to. Unfortunately it results in dead air while doing so. They issued a TSB about this. The fix was to go into the radio's settings and turn this feature off.
I don't recall the name of this feature, the TSB number, or how to turn on t he settings menu on the radio. I hope this will either spark another's memory or give you enough to search on.
John
John
The following 2 users liked this post by Johnken:
Lady Penelope (07-15-2018),
marvin.d.miller (07-16-2018)
The following 4 users liked this post by Johnken:
marvin.d.miller (07-14-2018),
rothwell (07-13-2018),
VinceCh (07-14-2018)
marvin.d.miller (07-17-2018)
seamagineer
40
03-20-2011 11:57 AM
