Radio - no sound
Thank you for your reply. It worked the first few month. The antenna was slightly bent so I kept it in the up position and disconnected the motor. I don’t remember seeing an amp but will check again today.
Fyi amp is on shelf above cd changer.
Do you have "tweeters" in the door's sail? I could be wrong but I think that IDs premium.
"Sail" = the sail shaped triangular area from the of front windows, inches from outside mirrors.
If still no go, please say:
if cd holder loads / unloads properly.
If radio lights up.
John
If radio lights up.
John
Received 1,665 Likes
I had the same symptoms, but no easy way to test the amp.
Ebay had numerous amps for sale with the correct part number, starting at about $35.
For that price I felt I had little to lose and bought the cheapest one on eBay for under $40 including shipping. Luck was with me and the used amp fixed my no-music blues.
worth a try.
Z
worth a try.
Z
Gladiator26 (01-06-2023)
I’ve had my power antenna fuse pulled for
so long I forgot the antenna is there. Just no need for FM / AM until the apocalypse. And the rest of the sound system is independent from it.
Z
PS perhaps I should mention that the amp worked intermittently for about a year before it died altogether.
Z
conor
11-14-2017 11:56 AM
