Radio question
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I have a 2002 XK8 Convertible. When I turn my radio volume up past 20 the dash board speakers cut out and I only get the lower speakers to work. Almost like some sort of protection kicking in. My question is do I have a issue with the speakers or the amp portion of the factory stereo? The fix usually is to turn the volume down and turn the radio off for a few minutes. turning the volume down and turning the ignition off and back on also fixes the issue.
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
I didn't even know it went up to 35 but after testing can confirm that my premium sound system does NOT cut the dash speakers out after 5 minutes at maximum volume.
You might want to remove the speakers and check if they appear to be aftermarket replacements.
I do not know for sure if Jag used 2 or 4 ohm speakers, but if they were originally 4 ohm and were replaced with 2 ohm, that could potentially overload the amplifier and cause it to temporarily shut down as protection.
