Radio Volume Knob doesn’t work
It seems I’m running out of things to fuzz about on the car. Among my current problems include:
Regarding the volume control knob, I’ve tried blasting CRC contact cleaner to no avail. I can’t figure out how to remove the knob. Until a solution can be had, I control my volume through the steering wheel buttons.
My car has the Alpine premium system and it’s an ‘04 XKR.
- Driver’s side valve cover gasket is leaking a small amount of oil, but not enough to be a concern.
- Weird interior creak from passenger side rear that I haven’t pinned down yet nor can I replicate when the car is stationary.
- Volume control knob does nothing at all except on and off.
Daniel the knob just pulls off, although kind of hard to get a grip on it.
Mine has gotten dirty like that a couple times. A good blast of cleaner directly on the pin under the knob, with some rotation, has always got mine working smoothly again.
Worst case in getting the knob off would be removing the radio unit and unsnapping the entire front cover then using the cover to ease the knob off since it goes under the knob. I did that the first time when I was not sure how it came apart.
MsMaybe98 (05-21-2022)
I knew this applies to the 4.0, but does it also apply to the 4.2 like mine?
GGG (10-15-2019)
Ok, to give an update to this, nothing ever worked. I ended up dismantling the radio to discover that the rotary encoder was actually broken. I tried sourcing a new one to no avail. I am living with it since it is only a minor annoyance.
Paulbell
Audio/Visual Electronics
03-26-2023 04:35 PM
