Radio went dead after battery disconnect
Jetjock, Look in your paper work for a radio code. A four digit number, If you have all the paper work with the car it will be on a card, I have found them written up in the corner of a page that shows how the radio works. A Jag dealer can give you the number if you go there and show proof of ownership and the VIN number.
Wayne
Wayne
No radio code!
Thnx for the suggestions but unfortunately did not receive original paperwork fromthis US car when imported to Canada. Radio seems dead so not sure if entering a code would work. Looks like I should try the battery reflash procedure where the ground wire is connected to the positive terminal for 10 secs than reconnected. Sort of like a reboot!
MediaBobNY (06-20-2015)
It is easy to miss a hairline break in a fuse, especially if you are looking at all of them. I suggest replacing fuse F9 (10 Amps) and F12 (5 Amps) on the passenger side of the dashboard, or at least checking them with a multimeter.
Malihide
04-02-2016 04:05 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
