Rainy days and wet carpet
So it has been raining here on the sunny coast of California and I have had to leave my 2001 XKR convertible out side a couple of times and it seemed to be holding out the water water. However, yesterday I got in it and a got a wif of the dreaded mold smell. I checked under the floor mates and found the carpet on the passenger side is wet. The driver side is dry. Does any have a thought as to where the water might be coming in? Thanks for the help.
Received 4,319 Likes
Open the hood and look under the cover next to the firewall, right side of car. There is a tube that is attached to a rubber hose. If the funnel is not attached water will build up in there, if you are lucky it will drain into the car, if not you control modules are in this section.
There is a little tab for the tube to attach too. One on the other side also.
Wayne
Wayne
