Random Overheating
Random Overheating
I have a 2001 XKR, undersized pulley (16 lb boost), large, extra heat exchanger, newish radiator, water pump, thermostat, hoses etc.. My car overheats on hot days (I live in Las Vegas) when moving in slow traffic. It is very random maybe does it once a month or so. Before this car I had a 1998 KX8 that did the same thing! I was never completely confident with it or the XKR. Yes, I have bled the system of air.
Does anyone make a stronger pump? Electric pump conversion? I have worked on cars for over 50 years and this situation is quite frustrating. Any help would be greatly appreciated.
thanks
Will
thanks
Will
is it overheating or just getting close to the red zone. stop and go is the worst as it heats up the pistons with low coolant circulation. i can get up to about 220-224 in stop and go on a hot and humid day, but this is not overheating. the scale on the gauge makes it seem worse than it is.
Received 4,331 Likes
Desert climate challenges coolant system
+1 to the above.
Well, here in Bahrain, I would say that the desert climate, in the Arabian Gulf, challenges the X100’s cooling system. As a daily driver, sometimes on the go all day in all sorts of traffic conditions, I can safely say my 1999 XK8 NA cooling system is going well, but with routine checks and maintenance.
Not sure how you’re reading your temps, but if you have it over OBD, post results here. Temps do fluctuate.
I would advise the following, if you haven’t already done so.
1. Check fans are ok and working
2. Check and Clean radiators of any signs of debris and clogged dust/sand. At least once a year, preferably before the hot season, wash down the radiator thoroughly. You’ll be surprised at the dirt and muck that comes off it.
3. Fill coolant expansion tank up to top when car is cold.
You should routinely (me once every 2 years) flush and refresh the entire 9L of coolant. Some use a special cleaner to remove any gunck in the system. Some in Texas mix anti freeze, distilled water with a “water wetter” as the coolant. I haven’t needed to do that... yet.
Also if the car overheats at the beginning of a drive, the thermostat needed changing, as it’s stuck closed.
Let us know how you get on in LA.
Use of AC makes cooling more difficult
Also if you have the AC on, it’s an additional “load” so more difficult engine cooling. High ambient temps don’t help the heat exchange.
In emergencies here, we learn to switch off the AC and turn heater up to max. That’ll help cool the engine. But it won’t be comfortable for you!
I live in the Palm Springs area where the temps average between 115 and 118 degrees during the summer. Sometimes hitting 130. My solution is to not drive it during the summer months. Occasionally I will take it for a quick spin at night when it gets down around the 90's.I recently went through my cooling system and replaced everything, except the radiator. I also keep it garaged in order to protect it from the sun. Black convertible with a black top is not the best car to drive in grueling heat. Driving with the top down is like being in an oven.
DavidYau (07-13-2019)
While our summer heat does not approach your Palm Springs temperatures, driving a top-down convertible here during the summer months is indeed miserable. A 98-degree day with 90% humidity is no fun at all. If I drove around for more than 20 minutes I would sweat enough to fill a bathtub. Autumn is the ideal season for top-down cruising around here. By the way, how far are you from Frank Sinatra's old 1950s-era "Twin Palms" home? I believe it is a short-term rental home now, probably going for astronomical rates....
https://pshistoricalsociety.org/prod...e-movie-colony
Architecture: Twin Palms for Sale ? Frank Sinatra's Desert Bachelor Pad | Ultra Swank
It's now 11:30am and 114 degrees
wickfordriver
02-02-2022 09:08 AM
slburns538
51
08-16-2019 10:49 PM
