Random piezo buzzer beeps? Also my turn signals stopped tick-tocking...
How's that for randomness?
I have this medium-tone piezo buzzer sounding 'BREEP' that goes off a couple scattered times whenever I'm in the car for at least 20-30 min. I can't tell from where behind the dash it's coming from. I do have a K40 radar detector built-in, but it's even switched off and the hidden red LED light for it (works) does not illuminate whenever this sound is heard. Sounds different too. Very odd.
Possibly unrelated, the 'tick-tock' relay sound of the turn signals has also suddenly vanished. Turn signals themselves still work (all 4). Has the relay simply gone bad? I had this happen in a previous car.
Any ideas?
Any ideas?
![Icon Handball](https://www.jaguarforums.com/forum/images/smilies/icon_handball.gif)
The turn signal sound and the various warning chimes all play through the small speaker situated in the steering column shroud -easy to get at.If the other chimes as well as the turning signal audible warning are not working it's probably the speaker - they are about $30 from a dealer.If you need it I can search through my records for the part number - just drop me a p.m.
Interesting. A relay built into the hazard switch is what made that sound on my old Passat. Sounds like British engineering!
No airbag light (or any others), so it's not that, unless that light burned out... will check to see if it comes up once normally on startup next time. I'm sure any little speaker would work as a replacement, but odd for that to go out- usually they just blow out, still work, and sound horrid.
I've got an extra couple laptop speakers lying around doing me no good yet. If this is it and fixes it, I'll send the other one to someone here.
giandanielxk8 (01-14-2013)
Once you get it working you will have a new appreciation for the unique, lovely and refined 'knock on wood' blinker sound vs. the click-clack of the relay in most cars. It is one of the little things that makes this car a special experience.
![Icon Speaker1](https://www.jaguarforums.com/forum/images/smilies/icon_speaker1.gif)
NikasilNik
giandanielxk8 (01-16-2013)
I had the same problem with no sound from turn signals, emergency light button etc so look forward to hearing about the fix. Someone suggested using cheap earbuds/headphone, cut the wires and hook on to the speaker leads to see if there is sound. If it does, it has to be the speaker. Am busy finishing up new hydraulic lines for the top, so this is next!
Update several months later... after leaving the car down for a few months while I replaced my hydraulic system, the turn signal's tick-tock is back! Battery stayed connected. Very odd. May still be a short somewhere, but it's been fine for a week. Still haven't heard that piezo buzzer sound since the last update. Anyway...
