Rapid battery drain - ammeter and oil press red lights on
light on with ignition switch off and key out
1. new battery within last year
2. battery discharges within 5-6 hours after charging
3. red warning light on on ammeter and oil press when key is not in ignition
Saw some threads about bad ignition switches - mine seems to click through each position well
Any wisdom?????
Key out, drivers door open, does chime sound (like you left keys in ignition)? Oftentimes the flap that covers key hole gets stuck up. Car thinks keys in ignition, battery drains. Happened to me last week.
This is 1 of many possibilities, just getting things evaluated and eliminated with you.
John
John
xk8newbie (07-13-2019)
Apologize for not being more thorough before posting. Double checked the positive and negative terminals of the battery - all I did was touch the negative braid that is grounded to the frame and the trunk lights came on - not sure if it is the battery side or frame attach point but will be removing and cleaning both.
Some Day, Some Day
07-14-2018 09:15 AM
CraigNelson
E type ( XK-E )
07-31-2015 12:22 AM
statfunk
04-21-2015 03:52 AM
