Rattling from back of car?
I have been trying to find rattles in my car but I have had no luck so far. The one in the back is the most annoying, it sounds like it's from the rear left and right hand sides almost like rattling glass but the windows are in solid. I taped down a clip that was loose in the rear wheel arch but that didn't change anything. Anyone know what to look for?
toaster (07-31-2022)
Edit: I can't quite reach the tightening mechanism, is the cable meant to be a little loose? The ones that run from the brake drums. It's like a sleeve and I assume the cable runs inside it. I will have a look in the morning though because it's night at the moment. I might be trying to get to it from the wrong angle.
Internal valves in the rear shocks can break off and rattle around inside the shocks. The shocks continue to function normally. The fix is to replace the shocks. This rattle drove my wife crazy back in 2014 before we finally figured it out. The rattle could not be heard with the top down, but with the top up it was indeed annoying....
giandanielxk8 (07-30-2022)
Hey.
Rip out all of the liners from the boot including the vertical cover behind the petrol tank. Looking at the left side of the tank, you will see a fuel hardline running fore-aft near the bottom of the tank, nestled right down in the narrow valley between the tank at the fender arch. That's where I found my 'knock'. Took me bloody ages to find it.
G.
G.
Hey.
G.
G.
michaelh (07-31-2022)
As per the OP's comments, any small loose object in the car sounds like someone hitting the car with a small hammer. Unbelievable how sound travels within.
Gaz.
I found the rattle, it turned out to be that little clip nub holding the carpet to the boot lid. Such a tiny little peice I could hear it all the way to the drivers seat even at speed and even with an aftermarket exhaust. I just taped it to the boot so it can't move around anymore.
8^)-
Now would be a GOOD time to get a picture of the VCATS label. (or write all the info down?)
Received 2,427 Likes
motorcarman (08-02-2022)
