Real Gauge
Real Gauge
Just installed the Real Gauge, sold by TheJagWrangler, nice product. Everything went well with the install and the start up. The instructions were very detailed, easy to follow and although I have been wrenching for 30 plus years I think the average DIY could handle it no problem. The Posi Taps were a bit fiddly at first but got easier to use as you went along. It is scary how uninformed you are with the stock gauge, there is quite a bit of needle movement now. It seems to work between about 187-200 degrees depending on driving conditions. This product is worth the money for piece of mind alone.
WhiteXKR (04-11-2014)
I am considering your request.
One issue is that the voltage at the front of the car varies like mad due to the varying loads over the long power cable runs to the battery in the boot. To do this properly and get stable readings, a pair of voltage sense wires would need to run all the way back to the battery, so some interior dis-assembly would be needed to run the wires.
