Real gauge videos?
No video, but the normal range is about 10 PSI to 75 PSI. Here are typical readings:
Idle cold can be very high due to cold, thick oil and reach 75 PSI where it is pressure limited.
Idle hot after a thorough warm up can show the lowest pressures, at around 10 PSI.
Running hot depends on throttle application, with typical cruise speeds yielding 35-60 PSI.
RaceDiagnostics (02-18-2015)
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
