RealGauge Installation Experience
Having purchased an unusually fine '04 XK8 in March and not that knowledgeable with the "interesting" aspect of the breed I joined the forum and began to read every thing I could about my new joy and what can go wrong with one. Most of the items of concern I read about appeared to have been addressed by the past 2 POs, including green shower, water pump, thermostat, hoses, etc and a 60k service at the a TN Jaguar dealer(PO sent me detailed service records) 2 months before my obtaining the car.
My continuing research on the forum kept mentioning a add-on called a RealGauge. Again the engineer in me resulted in studying anything I could about the RG. I contacted TheJagWrangler.com and a few days later my RG arrived. My good friend & I commenced the installation. Cut to the chase-we are a couple of 70's+ retired guys with less than keen eyesight or surgeon's hands. The instructions are spot on, understandable, clear and detailed. We encountered a couple on hiccups where we didn't follow the instructions but a call to WhiteXKR set us straight. My '04 did not require calibration and the two step tests sailed through.
If you have an XK8 and have not yet installed a RG, I can't urge you strongly enough-order one, and btw, follow the instructions and you won't have difficulties.
Thank you WhiteXKR for your courtesy, helpfulness and quality. GET ONE NOW!
The following 5 users liked this post by Orthodixie:
Charbinjr (06-13-2017),
Diddion (06-13-2017),
GGG (06-13-2017),
laguillotine (06-14-2017),
sklimii (06-13-2017)
So many of us have unresolved issues with the steering wheel tilt/reach drives it is worth noting that RG install is easy with the wheel fully back and down. Anything less than that makes the cluster removal/install a bit more of a challenge.
Message being fix your tilt/reach problem before doing the RG install.
The following 2 users liked this post by test point:
Orthodixie (06-13-2017)
