Rear ABS / Trac Reluctor Ring
The wife's 01 xk8 had a loose left rear wheel. The axle nut had come slightly loose. Seemed easy enough to tighten and locktite.
However, when its tight, the tire now rubs the metal/rubber axle bumper on the frame. It appears the wheel goes on about a mm or so too far.
I inspected the bearing and seals and they all are in good shape.
However he ABS reluctor ring appears to have a slight groove in it on the outside edge.
So off to ebay I go to get a new reluctor ring.
WTF! WHY IS A REAR ABS RELUCTOR RING 300+ DOLLARS?!
The front reluctor is like 40?
So I guess my question is, has anyone had the ring fail where it gets a groove in it?
Not getting any warning lights or any trac nonsense...
al_roethlisberger
04-05-2016 10:12 PM
