Rear Brake light on/off button??
Letmyhairfly (04-29-2014)
Sounds like you've found the Rear Fog Light switch, used to help keep you from being rear-ended in foggy driving conditions. These are not the same as the brake lights, as you'll see if you put them both on together. They've been mandatory on European cars for many years now.
The Rear Fog Lamps only work with the Head Lamps or front Fog Lamps switched ON.
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/82250-rear-brake-light-off-button-fog-lamps.jpg?amp;d=1398843913)
If you don't have the Handbooks/Manuals for your vehicle, they can all be downloaded from here:
https://www.jaguarforums.com/forum/x...006-faq-67827/
innzane
09-02-2015 10:08 AM
