Rear Bulb Failure Message Even Though Bulbs Are Working
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I am getting an intermittent Rear Bulb Failure message even though my rear lights are working. Does anyone have an idea what may be causing this?
The problem may be connected with the left, rear side marker socket needing replacement. I am not certain it is, though, because the side marker socket and light have been out for a long time and I just started getting the Rear Bulb Failure message recently. I will be replacing the side marker socket and light this weekend, but I suspect this will not solve the mystery of my intermittent Rear Bulb Failure warning.
Sometimes I get the warning immediately when I start the car. Sometimes it only first comes on when I apply the brake. Sometimes it only first comes on when I put on the left blinker.
I have changed the left blinker bulb and the brake light bulb, but those actions did not solve the problem.
Anyone have an idea what may be behind this?
Received 2,380 Likes
The symptoms you describe, other than getting the error at first switch-on, almost certainly point to a bad earth on the left rear lamp cluster. Adding a separate earth wire should solve your problem. Probably worth fitting one to each side.
Check this link on a resolution:
https://www.jaguarforums.com/forum/x...esolved-35083/
I doubt the side marker is an issue; they are not monitored for bulb failure.
HTH,
Mike
HTH,
Mike
Jersey City Jaguar (02-24-2015)
Jersey City Jaguar (02-25-2015)
Check the battery. Recently the battery in my xkr decided to up and quite on me. First it told me rear lamp was out and it was blinking weird at the dash....All lights worked when checked. Started it up next day that went away. Then my cruise wasn't working...Then lights again...Then my trunk was open....Then .....Anyway...Just get your battery checked regardless. These cars drive me batty.....Same thing happened with my xkr last year as well.
[QUOTE=Jersey City Jaguar;1168933]I am getting an intermittent Rear Bulb Failure message even though my rear lights are working. Does anyone have an idea what may be causing this?
I know that this is no help, but I had the same problem with a 1999 BMW 329ic convertible which preceded the Jag. My solution was to swear at it, tell the car that there was nothing wrong with the brake lights, and then ignore the message until it went away. Quickest way to banish the message was to stop and restart the car.
David
David
Jersey City Jaguar (03-26-2015)
Got the same issues at the moment. After reading this thread (and the linked ones), I had a look at my rear clusters. Found the earth pins were badly corroded/burnt:
![Name: IMG_4001.jpg
Size: 44.3 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/154507d1501209461-rear-bulb-failure-message-even-though-bulbs-working-img_4001.jpg)
![](http://i18.photobucket.com/albums/b121/aardvark_1964/Jaguar%20XKR/General/Rear%20Clusters/IMG_4004.jpg)
![Name: IMG_4005.jpg
Size: 62.0 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/154508d1501209461-rear-bulb-failure-message-even-though-bulbs-working-img_4005.jpg)
Having cleaned the pins up, the problem with spurious bulb failures has gone away. But tomorrow's job will be to add new earth wires and thereby ground the clusters properly.
Question is, why does this happen?
Gotta love this forum, though...![Icon Surfing](https://www.jaguarforums.com/forum/images/smilies/icon_surfing.gif)
Best wishes, Colin
Best wishes, Colin
Simples. The connectors aren't up to the job.
Each contact except the earth/ground feeds 1 bulb only.
Imagine a foggy night; you're turning left, so your fog, side, brake and turn lamps are all busy. The return path for all of these is - the single earth/ground contact.
Fast forward several years:- the pads on the lamp module get dirty, the contact springs weaken so contact isn't quite so good as it was when new. Arcing happens, burning the contact which makes it worse and... you have seen the result.
To be fair, it's not just Jaguar. How many cars have you followed where the driver brakes and the rear end lights up like a Christmas tree?
Economics. $5 less spent on connectors = around $450,000 saved over the production run.
And agreed, the contribution this forum makes to us all is invaluable.
Best,
Mike
Best,
Mike
Yeah, I wonder who thought of this improvement? We should call it "the [last name] mod".
I remember there was 1 like that on XJ6. Someone discovered you could put an on off switch in line with a certain wire. Flip the switch and climate control opened up outside vents without any fans. Gave a nice air flow while driving. Think it was called the Kelly mod, but too long ago to recall for sure.
John
John
...think he was the first to suggest it on the forum:
https://www.jaguarforums.com/forum/x...83/#post189211
Johnken (09-13-2018)
Tony K
03-26-2024 01:53 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
