rear bumper bolt spinning
It might help to see what the bracket looks like:
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-17/22617d1345281805-rear-bumper-bolt-spinning-03-bumper-bracket-new-jpg)
Be thankful our UK bumpers are less complicated than the US energy absorbing variety!
The problem is that the hexagon bolt (item 5) which goes up through the bracket (item 3) from the bottom screws into a brass nut (item 6). This nut is in the bumper plastic beam (item 1) and often breaks away and just spins round as the nut is turned.
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-17/22618d1345282271-rear-bumper-bolt-spinning-xk8-bumper-jpg)
It should be possible to remove the bracket fixing nuts and take the bumper and brackets off together.
![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
Note where this one sheared. This is the best place to attack them.
Here we go.
Reversing aid harness off.
![](http://racediagnostics.com/cms/uploads/images/jag/bumper/reverse%20harness.jpg)
Next I used this to cut through most of the bumper pillar.
![](http://racediagnostics.com/cms/uploads/images/jag/bumper/dremmel.jpg)
Access was limited so I was only able to cut about 3/4 of the way around.
![](http://racediagnostics.com/cms/uploads/images/jag/bumper/tower1.jpg)
A hack saw blade did the rest.
![](http://racediagnostics.com/cms/uploads/images/jag/bumper/hack%20saw.jpg)
I could then tap the bumper off leaving this.
![](http://racediagnostics.com/cms/uploads/images/jag/bumper/tower%20base.jpg)
I was worried these would shear off but the came out easily.
![](http://racediagnostics.com/cms/uploads/images/jag/bumper/bolts.jpg)
Next, how to get the bolt out.
![](http://racediagnostics.com/cms/uploads/images/jag/bumper/brass%20nut.jpg)
Drilled a couple of holes.
![](http://racediagnostics.com/cms/uploads/images/jag/bumper/brass%20drilled.jpg)
And put in a couple of self tappers.
![](http://racediagnostics.com/cms/uploads/images/jag/bumper/self%20tappers.jpg)
The bolt then came out easily, the bracket was in a mess.
![](http://racediagnostics.com/cms/uploads/images/jag/bumper/tower%20top.jpg)
Now on to the actual job of trying to unserseal the problem areas above the bumper.
Had the same problem ! Ended up being able to pull the bumper off the car once the fastenings behind the wheels were undone - the chassis mounts had pretty much disintegrated, the bumper was practically resting on the exhausts.
Replaced the mounts with new ones on the chassis, but on the bumper, I just used Araldite type 'liquid metal'putty to keep the brass ferrule in place. Slathered lots of copper-grease onto it of course.
![Name: P1030709.jpg
Size: 85.6 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/161405d1501267387-rear-bumper-bolt-spinning-p1030709.jpg)
![Name: P1030708.jpg
Size: 141.0 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/161406d1501267387-rear-bumper-bolt-spinning-p1030708.jpg)
![Name: P1030703s.jpg
Size: 103.3 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/161407d1501267387-rear-bumper-bolt-spinning-p1030703s.jpg)
![Name: P1030710.jpg
Size: 115.3 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/161408d1501267387-rear-bumper-bolt-spinning-p1030710.jpg)
Tar
09-06-2015 11:24 AM
philwarner
09-05-2015 10:05 AM
