Rear bumper problem
Rear bumper problem
Hi,
I have a problem with my XK8 2004 rear bumper.
The left beam mounting bracket https://www.sngbarratt.com/uk/#!/Eng...6-0d29da17980a had totally disintegrated.
Where the aluminum adjustable piece was, there remained only some small pieces and some white dust.
The right bolt going through the mounting bracket came out alright, but the left one I cannot get out.
The nut inside the beam is lose and just spinning.
I must take the bumper apart to get to the nut.
I found this instruction on the the forum:
https://www.jaguarforums.com/forum/x...stment-101947/
My question is:
Where can I get the nine new fasteners and center pins that hold the bumper cover to the beam?
Jens Lumbye
My question is:
Jens Lumbye
Just to clarify, do you really have to take the bumper off?? i.e is it hanging off?
I had a similar issue where one of the bracket to bumper bolt came out and the other just spins. I could not remove the bracket to car bolts as the heads are too rusty. So rather then cut off the bracket and replace it, then take the bumper apart and etc.. all which was looking to cost more and more I have just left it.
As you are in Sweden, I think you will have the non-energy absorbing bumper with the plastic beam? The energy absorbing version used in the US has a metal beam.
It sounds like you have got beyond this stage .......
........... and progressed to fitting the replacement brackets:
The steel hexagon bolts (see item 5) which go through the brackets screw into brass "nuts" in the plastic beam. These frequently seize and just rotate when you try to remove the hexagon bolt. You can be brutal removing the hexagon bolts by cutting off the heads. The brass "nuts then usually fall out of the beam (see item 1) and can be separated on the work bench.
New hexagon bolts (P/N JBU11218E) are available from Jaguar:
https://www.jaguarclassicparts.com/uk/part/JBU11218E
Rarely for Jaguar parts, these are very low cost!
markmywords (02-28-2024)
Copper lube is one of the greatest garage secrets
For those of us who keep cars a long time, copper anti seize lube must be one of the best garage secrets.
Still don’t know how exactly it stops contact corrosion, including steel and aluminium contact (bi metallic corrosion), but it works for years.... always.
hunterpedigo
06-21-2017 08:59 PM
hunterpedigo
10-29-2015 05:31 PM
Innovative Detailing
Detailing / Car care
01-24-2012 12:31 AM
