Rear bushings 2002 XK8
The usual failure is the 'A' Frame bushes (see RH arrowed in red):
Attachment 121182
Not difficult but requires a press to remove the old ones and fit the replacements.
However, there's several more bushes in the rear suspension. You need to add more details.
Attachment 121182
Thank you for your detailed reply. The bushings that were recommended to be replaced by the dealer were in the rear suspension, not the front. I hope this is enough information to determine what bushings are needed and to determine if this can be a DIY project.
Thank you.
Jamie
Jamie, that is a picture of the rear. Taking things apart is the biggest part of most jobs and this is one of those. You can take the parts to a machine shop and have the old out and new bushing pressed in after you get the old parts in your hand.
Sounds simple enough but the bolts and nuts have been under the car in all kinds of conditions and having the body supported and the tools will be a large portion of the ease of this job.
Wayne
Wayne
Wayne
Wayne
Jamie
I found the paperwork from the dealership and they recommend "to replace both rear shock absorbers (Found control arm bushing(s) excessively worn/loose". Are the shock absorbers and the control arm bushings part of the same assembly that need to be replaced at the same time? Is this a typical repair for a 2002 XK8 with 30k miles? Let me know your thoughts as so I can check SNG for the parts.
Thanks,
Jamie
Jamie, It's not the mileage but the age of the rubber that is the problem. Some go with the poly replacement, as they last longer in a age related situation maybe not wear, I don't know about that.
The rear shocks may just need the bottom bushing and they are cheap enough and can be done on the car, a video is available for how to do that part. When they are dropped down it will give you the chance to check the bushing and the shock. The other bushing of course should be looked over, as the dealer might be a little more **** than you and me.
Wayne
Wayne
Wayne
Wayne
Bob Boyle (10-07-2020)
Chapman
12-16-2015 04:16 PM
