Rear End Noise?
Play on rear bearings
Thanks for the info about the play. I am aware that some play is normal. My question is: Is that play adjustable? I didn't think so. Not like on some front hubs where you adjust with the bearing nut.
The paly on my right rear is so much that it makes a constant thumping sound. At first I though it was the upper shock mount. I took the sping and shock out, all lookked fine. Replaced mounts. Noise still there.
Besides spending $ 1,000 at the shop, any ideas? The service info shows that replacing the wheel bearing in the rear is a bit of an ordeal.
Rear Bumper noise
I had my 97 Jag XK8 in for an oil change and asked the mechanic where he thought my rear noise was coming from.
I found it coming from the rear bumper.
Seems after I had the car painted, the bumper snaps were off
on parts of the rear bumper.
I called the body shop and they said easy fix.
Thang Nguyen
10-12-2015 02:25 AM
innzane
09-02-2015 11:08 AM
