Rear hub connection with trailing arm bearing replacement
Ok, thanks. Yes the axle slid out easily. Will try to get the bearings and seals out gently using a flat scew driver. I bought all bearings, joints and bushings for the entire rear end. Likes to know that everything is up to standards. And on top of that, shipping is expensive, bearings and bushings are cheap. Better buy everything you might need in one single shipment. Thats my philosophy
