Rear main seal removal
I have a thread going on my xk8 project, but I need some help from anyone who has replaced the rear main seal. I have the tranny out but don't know if the special tool is needed to remove the seal or if anyone has done this with another method. Any help would be appreciated.
There are tools available, Jaguar JD229 or Land Rover 303-538 or Laser 6133. It is for removal & installation, basically consists of a cup, three bolts, six self tappers & a cute little thing to make holes in the seal.(laser obligingly give a nice picture of the set, sooo, if your good with tools).....
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
There are tools available, Jaguar JD229 or Land Rover 303-538 or Laser 6133. It is for removal & installation, basically consists of a cup, three bolts, six self tappers & a cute little thing to make holes in the seal.(laser obligingly give a nice picture of the set, sooo, if your good with tools).....![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Thanks, the tool is hard to source and pretty expensive. I called Christopher's foreign car parts and talked to Chris. He said they don't use the official tool. They use a punch and then a couple of metal picks to ease it out. I'll try that (without marring the outside surface of the camshaft.
![Icon Smash](https://www.jaguarforums.com/forum/images/smilies/icon_smash.gif)
RJ237 (02-19-2015)
Use a sharp pick to pierce the seal at three & nine o'clock screw in a couple of longish sellf tappers & it should pull out with two pair of pliers. For installation some just push in fairly easily others I've found fifteen minutes or so in the ice box helps + plenty of lube , maybe a piece of tubing of the correct diameter to tap it down evenly.![Icon Smash](https://www.jaguarforums.com/forum/images/smilies/icon_smash.gif)
MC36
US Lower Atlantic
09-01-2015 07:34 PM
