rear rattle shock bush fixed
fixed my rear shock bush today with the help of my removal reinstal tool thanks to XKRacer and steveinfrance and others ..only need the tool and 2 jacks jack the car and the the suspention your working on..had a job to get the bolt out..the bottom of the shock hangs low so you can get the tool in..old bush pushed out easy..had to take the rubber cover of the new bush..pushed in ok..refit rubber ....only remove one bolt need to do the job..
im happy to lend the tool out
the biggest problem i had was getting the bolt out..pushing the bush out and the new one in took minuits..once youve got the bolt out its easy..total work including useing a big hammer.about two hours..
I think the bolt was rusted on to the inner part of the bush..after banging away with a small hammer for a while i got my lump hammer out and gave it a few clouts ..that did the trick.
KarimPA
09-12-2015 08:15 AM
