Rear Seat Removal
Old 08-29-2009, 08:47 PM
Robscountach's Avatar
Default Rear Seat Removal
Well, the Passenger Quarter Window doesn't go up/down, just sits there and 'grinds'. I can pull it up/push it down; However, the top doesn't work because of it as I'm sure there's a limit switch not being activated.
I'm sure its the regulator, but it 'might' just be off the track, so how do I get to it ? It seems like I've got to remove the rear seat/subwoofer ???
Thanks in advance !
Old 08-29-2009, 09:20 PM
Gus's Avatar
Gus
Gus is offline
Received 2,216 Likes on 1,703 Posts
1. Removed the rear seat 2 nuts located at the floor, and rear seat back 2 screws at the bottom.
2. Removed left or right rear cushion over the top of the speakers. 3 screws each.
3. Removed speaker covers left or right. They will snap out but have a plastic trim finisher in the rear. Just pop them out.
4. Removed speakers left or right. 2 nuts at bottom and 2 screws left and right of each speaker. Remove 2 plugs each. The speaker is a little hard to remove with the brace above it in place but can be done.
Or you can go to my webpage and go to roof hose replacement. I have a few photos that might help.
Gus
Jpav27
07-31-2022 06:43 AM
jdzubas
10-04-2015 09:14 AM
davidladewig
09-03-2015 06:32 PM
Joey T
09-03-2015 05:31 PM
Dallas XK8
09-03-2015 12:17 PM
Quick Reply: Rear Seat Removal
