Rear Seat and Trim Board removal
JTIS - 1997 XK8 Coupe - Rear Seat Cushion.pdf
JTIS - 1997 XK8 Coupe - Rear Seat Back.pdf
The 'metal board' is called a Treadplate. The section with 'Jaguar' on it is the Treadplate Insert. I've never removed one but according to the Parts Manual, it's held on with six M6 paint clearing screws.
The following 3 users liked this post by GGG:
The treadplate insert is fastened with very strong double sided tape. Heat it generously with an electric heat gun while gently lifting it up. You need to be very careful not to bend it or it must be replaced. I start at one end with a knife and then pull it along and up with 22 ga. solid copper wire so as not to scratch anythng. Once it is up you will have access to the screws. If you keep it clean it should be sticky enough to reuse without additional adhesive.
Mendo XK (07-26-2012)
davidladewig
09-03-2015 06:32 PM
