rear shock bottom bolt stuck
BACK ONCE AGAIN WITH A PROBLEM ... I'm removing the rear shock and coil spring to replace the both . I have the coil spring compressed. and everything out of they way but I'm stuck on one bolt that will spin freely but won't budge back out i tried hitting it out with a mallet at full force but its still not moving a bit . Can someone please tell me how they got it out...........its almost s if the shock is putting enough pressure on the bolt to keep it in there .
![Icon Viking](https://www.jaguarforums.com/forum/images/smilies/icon_viking.gif)
Same situation when we changed rear shocks. Had to take rotary tool and cut off wheel to remove the lower shock eye. Made 2 cuts on lower shock eye and removed it from the bushing, then made 2 cuts in the bushing and removed from the bolt. Damaged the bolts while making cuts so we replaced them with new ones from a E-Bay vendor who is also a Dealer. # JBZ100036 fit my 2003. $10-$12 ea. incl nuts. Use adequate anti-seize JIC.
Siebert22
03-09-2016 10:04 PM
