Looking for some advice. Taking out the rear subframe to carry out a repair to the chassis legs for the A frame and managed to shear these bolts. (BH21209MJ Item 16)
SNG Barratt dont stock these and have said they are no longer available.
Could anyone tell me the thread for these bolts or any suitable alternatives they've found?
Note #8 and #16 above show as the same part. Might be worth giving the dealer a call. I've sourced parts from my local when Heritage has shown no stock.
Price isn't insane either, unlike others quoting $40 - wtf?
WOngu the bolt you have indicated is fine thread M12x1.25 pitch and 45mm long (not including the head) and its only part threaded.
from SnG you can get sh212401mj this is M12x1.25 pitch but only 40mm long (not including the head) and its fully threaded but should work.
Ebay have M12x1.25 pitch and 45mm long (not including the head) and part threaded.
Left bolt from ebay, middle bolt is original, right bolt is from SnG
Really helpful information. My local do not stock any of the bolts so this is perfect information.
Managed to find a suitable ebay replacement with this, so I can crack on with getting the subframe back together now!
