rear subframe removal
Hi,
I have a leaking dif front seal that needs replacing.
I have my car up in the air, 24" and have removed all the neceassary fastenes except the remaining front subframe ones.
I'm handling this repair myself and am wondering if I can 'semi' safely drop this rear suspension assembly by myself with a 2 ton jack (or two)?
wj
wj
I did the same as you and discovered that the Diff assembly is really heavy and awkward to find centre of gravity with a trolley jack. It just wasn't safe enough to continue as a one person job. In the end I reduced the mass by partly stripping the assembly and used a Motorcycle lift to lower the whole lot and also to lift it back in. Much safer this way and I also used wooden planks to chock each stage and keep it balanced.
Hi,
wj
wj
motorcarman (08-08-2024)
Of course, changing or topping up the diff oil is a nightmare job on some versions of the X100, actually harder than changing the pinion oil seal. There are ways around this but dropping the diff does make changing the oil a thousand times easier.
Richard
Also, don't forget to first detach both the 'hidden' exhaust brackets on top of the Axle (see 2nd pic).
Alright, opinions please.
Both of these can be purchased for a reasonable price.
This adapter unit uses a ½” thick bolt to attach to a floor jack. I have several 2 ton jacks that could accommodate this type if mounting.
The Harbor Freight screw jack might also work, the upper platform is rather small and I think balancing the suspension might be more of an issue with it.
I appreciate everyone’s thoughts on this.
wj
wj
Red (08-13-2024)
wymjym (08-14-2024)
