rear suspen - page link needed
WJ, best I can think of is the Workshop Manual. Section 204 = Rear suspension. My copy is nearly 80mb so I can't attach it.
I'm sure I downloaded it from a link I saw here a few years ago. Thinking out loud- I've seen that link posted several times since.
I'll take a quick look, if ngood maybe someone remembers?
John
John
thanks folks, I found this while searching:
https://www.jaguarforums.com/forum/x...-frame-106228/
My car went from being totally predictable to not.
My alignment shop told me that the front control bushes were bad and that was the cause...so I replaced them,replaced the upper/lower front b joints, replaced lower shock mounts and when driven everything is tighter and the problem continues.
I must concentrate to keep the car pointed where I want it but it does not drive left or right nor does it pull. I used to be able to thread a needle at speed with the car now I'm lucky to keep it within the lines @ 75mph. I must make slight adjustments continually. I'm thinking the rear toe is out but the fact that I can't determine any consistency to this behavior has me looking for a worn component.
wj
wj
I have the poly bushes...guess I need to roll up my sleeves pretty soon.
