Rear Tire Wear
Rear Tire Wear
'06 XK8
My mechanic told me the inboard edge of the rear tires were worn and needed replacement. I had him mount
Michelin Pilot Sport A/S 3 255/45/18 99Y
After 8600 miles, the tread was entirely gone on both, with the steel belts visible across the tire.
I don't abuse the car, never 'burned rubber' or squealed on turns. I maintain the tire pressure as specified.
I'm hoping the tires were defective, old, etc.
What longevity is 'par'?
I think your alignment, especially rear toe in needs to be checked. Your rears shouldn't wear much faster than the fronts. If your roads are unusually abrasive and your driving style aggressive you could go through tires that fast, but that doesn't appear to be the case.
DrOrb (01-30-2017)
What pressures are you running in your rear tires? I learned through trial-and-error back in 2012 that 28 to 29 psi is the sweet spot for my wife's 2006 XK8. Anything higher than that will wear the rear tires out prematurely right down their center tread. The sweet spot for her front tires is 32 to 33 psi....
It does appear that you have alignment issues. Worn upper shock mounts and lower shock bushings in these cars are notorious for affecting alignment. These components fail due to a combination of mileage and age causing the suspension to settle, throwing off the alignment geometry. Most of these cars that have not already had their various suspension components replaced by now definitely need the work....
My wife's 2006 XK8 received new rear shocks and shock mounts at about 83,000 miles in October 2014 and new front shocks, shock mounts, and upper control arm bushings at about 99,000 miles in January 2016. Now at 107,500 miles, her XK8's suspension is significantly better and the tires' treadwear is perfectly even across both axles again. Money and time well spent if you plan to keep the car for years to come....
DrOrb (01-30-2017)
DrOrb (01-30-2017)
DrOrb (01-30-2017)
Factory shock mounts last no more than 40k miles. The springs start sagging too, although they remain functional. -- just not up to spec
DrOrb (01-30-2017)
Like others I would suggest having the car aligned. They can make recommendations that you can act on or they might make adjustments that fixes the problem. I would suggest that you find the best pressure for your tires and check them frequently. I run 32psi and check the tread frequently.
DrOrb (01-30-2017)
