Rear tires cupping
Others have report top shock mounts in the rear causing noise. Cupping could be unrelated, or could be bad shocks, which could also be the noise. for the cupping, also be sure the toe is set correctly. Toe out on the rear (and front) will wear on inner edge and cause cupping. Camber can be off too, but generally isn't too much of an issue and can be compensated with slight toe in.
KarimPA
09-12-2015 08:15 AM
