Rear view mirror removal
mark.osterman (05-10-2021)
Services Sybesma's Electronics
Phone:
Fax#
I just sent my mirror off today.
Phone:
616-392-6911 or
Tollfree 1-800-456-4265
Fax#
616-392-9885
I have not used radar-mirror but thanks for the info.
The following 2 users liked this post by motorcarman:
Don B (06-19-2022),
someguywithajag (09-11-2021)
Don B (06-19-2022)
#31
Hi, Just bought a used 2000 XK8 for my first car and I have half of my rearview filled up with the liquid you guys are talking about. I'm still a little confused about the best method of removal and if it would be ok to just stick an aftermarket mirror there as a replacement. Any tips would be helpful!
#32
To remove the mirror, you must slide it DOWN along the curve of the windshield. There is a small metal tang at the bottom of the mount that needs to be pressed to release the mirror- just can't remember whether it pushes towards the windshield, or way- just play with it. Be careful- many have broken their windshield by applying too much force trying to remove the mirror.
Replacement with an aftermarket is possible, but you may lose some features ( auto headlight dim comes to mind). Mine did not have these features, so aftermarket was OK, plus I wanted a rear view camera, and the one I chose has that built into the mirror. The mount is the issue, and the aftermarket I bought has mount adapters that worked with the stock Jaguar mount on the windshield.
I also found you can buy the mount adapters from Autovox, that might allow some other aftermarket mirror to fit. Just not sure if the adapters are specific to the Autovox.
#33
Just as an FYI, I recently replaced my defective mirror with one that includes a backup monitor and wi-fi camera. Easy to install. Came with adapters, and one of them fit the Jag windshield bracket.
Autovox T1400
Autovox T1400
Did that Autovox T1400 fit in your 97 XK8 ?
I have an 02 XKR with broken ball tabs.
#34
#36
#38
#39
