Rear wheel bearing install
#41
#42
I used a drift and a 3 pound hammer ( big hammer big improvement here) to hammer out the races. Keep the drift in the slot so as to keep the wall of the hub carrier unscathed.
Don't forget the old bearing pieces are a perfect match to the new bearings diameter. I often use them to press back in New ones or to protect the new one already in place if I press the hub into it.
John
John
zidjan (04-02-2018)
#43
Btw, yes one from each side. Don't forget that you can position the carrier so that instead of pressing the hub into it, you are pressing the carrier onto the hub. This is an example of my point - if you can't get the hub secure on a flat surface, invert the items an work from a different perspective.
Outer bearing in place, need to press in hub and spacers. Put a 2x4 on press table, place hub on 2x4 wheel bolts extended down and protected. Use a left over bearing piece to place on new outer bearing deliver pressure from inside of hub.
Gosh that sounds obvious, excuse me if it is, I just remember feeling smart when I figured that one out.
One more: I went to lowes and purchased plumbi ng connectors ( steel $5 ) when I needed a spacer 4 inches long id larger than hub, od equal or smaller than bearing.
John
John
#44
John
John
#45
Sorry, I’ve been quite busy lately, but it looks like these gents have been taking care of you quite well with their advice.
The races were not difficult to remove, nothing like getting the hub remove from the carrier like you just did. Hammer and a cold chisel/drift to remove them from either side. Pressing the new ones in I primarily used a 72 mm Pittsburgh Automotive aluminum adapter from a bearing race and seal driver kit, along with the HF press.
Johnken (04-03-2018)
#46
Agree with all of the above - would just add that if you cut a slot across the old outer 'shell' you can use it to push in the new one without any risk that it might get stuck. Plenty of different ways of getting the new outer 'shells' back into the hub carrier - I don't have a press so will use the threaded studding with some large steel washers and nuts to "pull" the new ones into the hub carrier. In the past, on other cars, I have gently tapped them in with a hammer using the old 'shell' to protect the edge of the new one.
Photo shows hub carrier after the 'shell' has been removed - you can see the slot that gives you access to the rear face to be able to tap it out with a hammer and drift (or old wood chisel in my case !!)
#47
#48
Thank you guys, I wouldn't even dare tackling something like this without the support of my Jaguarian members. I'll stop by HF and pick up some drift punch and maybe a 4lbs hammer.
I will come back with questions on how to pack the bearings back later on though since the bearing just fell off the carrier when I pressed out the hub out...so I'll be back!!
#49
I think the inner ones are fairly straightforward - as you say - they sort-of fall apart.
My "ongoing-project" is a complete wheel bearing replace on all four corners - I paid £200.00 (about $280.00 US) for a set of hubs / hub carriers from a breakers (parter-outer ??) here in the UK. They were in a pretty bad state but nothing a lot of heat and a big hammer couldn't solve !!
I'm still trying to sort out the front hubs / hub carriers - I enjoy a challenge.
The rears are fairly straightforward in comparison except I decided to replace the pivot bearings on the lower mounting bolt as well - will eventually post a thread, but will confirm now that four hands and a bit of ingenuity are required to get the outer bearing shells removed .
#50
Zidjan, Hope this helps: Drift - The one I used came to a 4 corner point. So in this case the tip is square, but one corner is a bit raised.
Man as I type this I realize how hard that would be to visualize. Imagine a square plane with an axis running through any 2 opposite corners. Now in your minds eye rotate the square on that axis a few degrees. One corner goes up, the other down. Since this one corner extends at the edge of the drift, not in the center like a punch would, it gives you a good place to grip into the slot without scoring the hub carrier and a way to direct the power downward.
Hope it helps Z.
John
Hope it helps Z.
John
#51
John - any chance you could translate that into English
#52
#53
The other side went pretty smooth as I smarted up a bit and decided to use the press and the drift to push the race out....
#54
zidjan (04-04-2018)
#55
John, I read this too late, I bought a punch set from HF I managed to get those races out but at a cost ...I nicked one side of the hub carrier I am guessing just a rookie mistake not really aiming what I was hammering at....I went with a punch that has round end... did I just F myself on this? or is this salvageable?
zidjan (04-04-2018)
#57
Thanks guys.... Next would be packing the bearings together...I'll read up this thread again for the other small details
#58
I have yet to reassemble mine but I think the strategy will be :
1. Press both outer shells into the hub carrier. I'll probably use the threaded studding, the old bearings with a slot cut in them, and a large metal washer to "pull" them in but a press would be a more efficient and quicker method.
2. Install the seal and inner bearing on one end of the sleeve and pack with grease.
3. Slide that into the hub carrier.
4. Slide on the large spacer and the thin spacer.
5 Put lots of grease on the second inner bearing and tap that on using a suitable socket.
6. Install the rubber seal over that second bearing.
Don't forget the two spacers that fit on each end of the "sleeve". They are different sizes and should be fitted in the same place that they were removed from.
Also - if it's not too late - the bolt that holds all this lot together is "eccentric" and should be fitted exactly as it was when removed.
#59
#60
