Rear Window brakelight
There should be two metal clips on the glass that snap into a matching pair on either side of the light assembly. The light assembly has some plastic tabs that snap into the interior colored cover.
So the glass holds the light that holds the cover in place.
The plastic bits of mine broke all to pieces so I ended up putting the light back into the housing with some double sided tape and then snapping it into the clips on the glass.
It's not as tight as original but seems to get the job done.
To install it, all you need to do is slide is down the glass until it pops past the metal clips on the glass. Removal is the reverse, just pull up. Plugging it in is sort of a pain as the wire harness is fairly short.
99xk8guy
06-05-2023 06:28 AM
