Rear wings/boot - Paint or Wax? Advice please
Lower rear wing sections accessible from inside the boot.
I have been de-rusting these for a couple of weeks now but were quite bad and still aren't perfect but haven't yet caused bubbling on the exterior of the wing.
Question I have is whether to paint with a good anti-rust paint with the risk of moisture creeping under the paint causing more rust in the future OR whether to use a 'corrosion prevention' wax e.g. Dinitrol ML which I have already injected into the chassis rails and sills?
I am leaning towards the wax but realise that if it doesn't work then it will be a b*tch to remove if I want to paint later.
Any ideas please?
![](https://farm9.staticflickr.com/8725/17177307540_5f70bcf159.jpg)
![](https://farm9.staticflickr.com/8884/17364872985_41f978e97e.jpg)
![](https://farm9.staticflickr.com/8877/17177312560_196d24e243.jpg)
Regards
Mark
Any ideas please?
Regards
Mark
Plums,
Yes I have used some quite expensive rust removal solution that is used in the aviation industry, however the area is quite pitted so I am never going to get down to 100% shiny steel.
I am just doing final prep (whilst we have some sunshine today) and am considering painting it then when dry flooding the area with Dinitrol.
I think that most UK XK8s will have this problem as it seems to be a rust-trap area.
Mark
Mark
The rustbusters paint I am using is 2-part epoxy so hopefully I will get similar results.
The reason for my question was that in a similar situation where access is limited e.g. chassis rails the normal procedure would be to use wax with the expectation that it would halt further corrosion.
WinterJag
16
10-09-2015 07:49 PM
davidladewig
09-03-2015 06:32 PM
