Rebuilt Engine
To quote Daniel Defoe "second thoughts are best".
Unless it comes from a reputable rebuilder with a convincing provenance and has a suitable guarantee, it looks too good to be true at that price.
most engines get rebuilt when they are tired or broken. My own preference is to buy a low mileage replacement. The exception, as others have pointed out is when the engine has been reconditioned by a really reputable engineer. So much of an engine cannot be returned to original spec, especially when the engine has broken. I'm afraid I've seen, badly ground cranks, worn heads with new cams fitted. Heads so badly resurfaced, you can put a fingernail in the scratches, and hellicoils! anyone who uses hellicoils extensively, then calls the engine reconditioned needs shooting.
Thirty years of discovering hellicoil springs wound around the bolt instead of staying in the castings. Timeserts aren't so bad but I prefer to use parts that are sound instead of 'best of a bad job' repairs. I would use timeserts to repair my own engine if I had to, but I think if you're reconditioning an engine for resale, you should use parts in perfect condition.
