The red scare in the garage
Tuesday morning I went into the garage to discover a huge red mess running out from under the Jag. The power steering pump gave out overnight. I had driven it the previous day and when making the curve into the garage to park her next to the other vehicle, I did hear a noise but thought I just turned the wheel too sharply (although I didn't bottom it out).
With all the sensors in these vehicles, I'm surprised there wasn't a warning that the pump was failing (especially since it beeps, squeals and lights up for every other minor item). Even with a good amount of fluid left behind on the garage floor I was able to get it to my closest mechanic (2 miles) without any warning lights where he replaced the pump, cooler and hoses. I would have thought my dash would have been lit up like a Christmas tree, if not before the pump failed, certainly after.
So my question is this: Are there no sensors for the power steering or did mine just not work and does anyone know if there are any other parts that aren't sensored that I need to have checked out? Does anyone know?
Received 2,191 Likes
Not everything gives warnign lights or check engine lights, some things are stored and some are not, and without flipping open the book and looking at all the codes for ps and fp sensor faults i couldnt tell you off the top off my head if they will or not. But i dont ever remember a check engine coming on for ps pressure, youll know cause your steering gets hard about the same time the light would come on to tell you
Looking at the Electrical Manual for the 2000 XK8/XKR, I can't find any reference to these sensors. In what part of the Electrical Diagram set are they located?
Reviewing the electrical schematics, the only PS connection that I could find (LL1) to the ECM seems to have to do with the speed sensitive control system. I cannot find any sensor to report PS fluid level or pressure or lack there of.
I also cannot find any fuel pressure related sensor or connected to the ECM except for the fuel tank pressure sensor, which appears to have to do with the evaporative control system.
It would be especially helpful to have a way to report actual fuel pressure other than screwing on a pressure gauge.
I do apologize
Red Scare in the garage
The only repair that required a tow was my fuel pump. I had no idea what was going on (no warning lights) until the mechanic stuck his ear next to the fuel fill and asked me to turn the car over. He then went to the fuel rail with a very high tech instrument - a Bic pen- and depressed what looked like a ball bearing and again asked me to turn it over. No fuel at the rail so he rightly diagnosed it as a fuel pump. But again no lights.
This issue leads me to a theory.The fuel pump failed immediately after I pick up the car after a two week vacation. She is a daily driver on her mile are 120,000+ with very few problems (wheel bearings and thermostat). I wonder if many of the cars on this forum who sit for weeks and months on end do a disservice to the car by not exercising the parts continually and then jumping expecting all to be well. Sort of like not working out and then expecting the body to do a marathon. Not happening.
Perhaps the morale of this story is to Drive your Cats!!
After 4 month Winter Storage, both of my Fuel Pumps were open circuit and had to be replaced. Before storing for the Winter, car (with 31k mi) ran perfect.
Sleeping beauty
neruda
10-18-2015 01:19 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
