Reduced Performance Error Message
OK, what did I do ( or didn't ) when I took a perfectly great running car and ruined it? At 70K miles I decided to replace the gas filter on my 2000 XK8 with a Mann filter, (not the easiest thing to do). After starting the car it ran fine for about 30 seconds and then stalled. For the next 30 minutes I made multiple attempts to get it running smoothly with "Reduced Performance" errors messages. Currently it starts fine, then goes to < 500 RPM, stumbles, shakes, and stalls with no throttle response. I checked the fittings and found no gas leaks. At this point I believe I introduced air into the injector system, but don't know if that's the real reason. Has anyone run into this before and is their a valve or hose I need to open to allow the air to bleed off. HELP....
Kurt
Kurt
There's nothing special to do re bleeding.
You can wrap some rag round the Schrader valve on the fuel rail and press the valve stem down with the ignition on - you should get a pretty good squirt of fuel.
If not - have you got the filter on the right way round (sorry...)?
If it looks OK + no fuel at the Schrader can you put the old filter back on ?
It is extremely unlikely you've caused any permanent harm.
Let us know how you get on with these simple checks.
Kurt (05-27-2013)
philwarner
43
09-10-2023 11:30 AM
KarimPA
09-27-2015 08:46 AM
Johnken
09-15-2015 05:46 PM
