Refitting Console With Key In Ignition Now Wont Start Limiter Not Available ?
![Arrow](https://www.jaguarforums.com/forum/images/icons/icon2.gif)
So I was refitting center console dash. I kept the key in the ignition then I try to open the driver door and it wouldnt let me. So I had to get out on passenger side. Alarm went off I pressed the key. Now When I put my key back in ignition to start I get these messages "Limiter Not Available" and "Cruise Not Available" it wont let me turn the key to start the car. Please help. Thanks
I would back-track whatever you did. Car worked fine I assume.....you did something with the console off.....put it all back....and now car doesn't work. I would think it is most likely that whatever you did either directly or indirectly resulted in your current situation.
Did you spill anything on wiring? Specifically what did you install / fix / do to the car since it last worked well? Did you disconnect those console harnesses and other harnesses while key was in ignition, battery was connected, and they were powered? If so, I would check fuses first....and there are potentially a lot.
Wolfy
05-28-2024 08:06 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Jaguar Forums Editor
Jaguar Press release
09-03-2015 09:38 AM
